Add the capability to rename PostgreSQL Geodatabases. Currently if the PostgreSQL Database is renamed it breaks the sde geodatabase repository because the database name is stored in many tables/rows in the sde repository tables. If the database administrator could rename the database then copies of the same geodatabase could be created in the same PostgreSQL Instance. This would be extremely helpful.
