64/32 bit problem with external data connections
5316
9
02-26-2016 05:58 AM
scottandres
Have you has solved this problem?  I would appreciate hearing from you.  Specifics follow…..
I have a Win7 x64 machine with functional 64 and 32 bit Oracle 12.1.0.2 run-time clients complete with functioning ODBC and OLEDB drivers.  Did everything recommended by Microsoft, Oracle, and “BIG TIP for ArcGIS/ODBC/OLEDB users on 64 bit Windows” post on GeoNet.  ArcCatalog will not create a connection to Oracle.
The 32 and 64 bit clients support SQL*Plus, SQL*Developer, and ODBC.     The 64 bit ODBC runs connections for 64 bit MS Office. Path and TNS_Admin environment variables are pointing to the appropriate home, bin and network/admin folders.  The 32-bit oracle client and ODBC connection have been named to clearly indicate that they are 32 bit.  This eliminates any confusion about what client is being invoked when configuring services.  The ODBCad32.exe in the syswow64 folder (see “BIG TIP…” post) creates a working connection to my oracle server.
My oracle db is using TCP and TNSnames and default port 1521:
  # tnsnames.ora Network Configuration File: \app\client\asa32\product\12.1.0\client_1\network\admin\tnsnames.ora
# Generated by Oracle configuration tools.
db32 =
(DESCRIPTION =
    (ADDRESS_LIST =
(ADDRESS = (PROTOCOL = TCP)(HOST = server1.domain1.edu)(PORT = 1521))
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = db1.domain1.edu)
The add database connection only allows a choice of “Oracle” for the database platform box.  It does not display specific information about the ODBC connection or Oracle driver in the instance box. Database authentication is used for all.
The ArcCatalog add database connection dialog will not connect to the Oracle server with any variation tried so far:
When instance is defined as db1:  Failed to connect to the specified server.  Do you want to continue? Underlying DBMS error (unknown errorNo extended error.]
When instance is defined as db1.domain1.edu:  ORA-12154 (TNS:could not resolve the connect identifier…]
When instance is defined as the alias “db32”: ORA-12154 (TNS:could not resolve the connect identifier…]
Following the naming advice in the on line help instance set to “server1/db32”:  Failed to connect to the specified server.  Do you want to continue? Failure to access the DBMS server
I would appreciate hearing how you would fill in the entries of the Database Connection dialog given the tnsnames.ora shown above or if you think this post should be tagged differently. thanks!
MichaelVolz
Esteemed Contributor
Is this setup being done to have 32 bit ArcGIS Desktop connections to Oracle and 64 bit ArcGIS Pro connections to Oracle on the same machine?
scottandres
That was quick, thank you
I don't have ArcGIS Pro. This is for 32 bit ArcGIS connection to Oracle.
Scott Andres
Delaware Geological Survey
University of Delaware
Newark, DE 19716
302-831-0599
www.dgs.udel.edu
George_Thompson
Esri Frequent Contributor
You only need the 32 bit client installed for ArcMap. Is the 32 bit client 1st or 2nd in the PATH variable (behind the 64 bit client).
Are the Oracle clients the full Admin clients? I am not sure about the run-time clients.
-George
Geodatabase
--- George T.
scottandres
thanks
the 32 bit client is referenced first in the path and tns_admin
variables. that fix was in the first group of tricks that was tried.
i have a run time client. Do you have experience or seen interweb
resources that reference success with the admin client?
Scott Andres
Newark, DE 19716
302-831-0599
www.dgs.udel.edu
George_Thompson
The Oracle Full Client (Admin) should have everything installed.
As an alternate for testing, you can install the 32 bit Oracle Instant client and add the folder to the PATH variable and test in ArcCatalog (after closing it down and re-opening it): ServerName/SID
--- George T.
scottandres
I have also tried the 32-bit Oracle instant client with the ODBC, OLEDB,
and ODAC components.Installation and configuration logs generated by the
installer show everything was successful..net-based apps with an
explicit connection defined in ODAC calls did function as did tests
with *.udl and *.odc methods.But OBDCad32 did not show that the ODBC
driver was present so not a solution for Arc.Posts in OTN forum and
Oracle docs indicate that this is the way the instant client is supposed
to work.The uninstaller was used to remove this client. Checks of the
registry don't find any litter that would interfere later.
Scott Andres
Newark, DE 19716
302-831-0599
www.dgs.udel.edu
MichaelVolz
Can you try removing the 64 bit Oracle client and just working with the 32 bit Oracle client?
scottandres
Yes a 32 bit client without a co-existing 64 bit client has worked
everytime for years. The 64 bit office apps are more critical to my
workflow so I have done without the ArcMap connection.
Scott Andres
Newark, DE 19716
302-831-0599
www.dgs.udel.edu
JamesGough1
ArcMap is a 32-bit application and you need to install the 32-bit version of Oracle client drivers like Oracle Instant client.
Then you need to add both the 64-bit and 32-bit oracle clients in your system path.  64-bit path first and followed by the 32-bit Oracle bin in the path.
You need to re-start ArcMap before attempting to connect so it can pick up the updated path variable.
The error you are getting says it can not find your netservice name in the tnsnames.ora file which should be located in the path you specified in the system TNS_ADMIN variable.
The name you specify for the for the Instance in the Oracle Database Connection dialog (should be db32) needs to match a Net Service Name in your tnsnames.ora file found in the TNS_ADMIN path.
db32 =
(DESCRIPTION =
    (ADDRESS_LIST =
I can work with you on this in a meeting.
You can contact me at jgough@esri.com.
Thank You,
Jim Gough | Technical Lead Enterprise - Educational Services
Esri
