Add coordinate system to shp-file
934
5
06-23-2011 04:39 AM
HartmutJunge
Some days ago I took over a "GIS"-project, created in Arcview 3.2. Unfortunatly my former colleagues edited the project without a coordinatesystem, also "local"-system.
The project contains approximately 2000 shp-files. Has anybody an idea, how i can add the local coordinate-system (UTM-WGS84, 39N) in one step for all shp-files? I can use an Arcview 9.3 of a partner organisation to do this job.
Otherwise, in Arcpad, I get bloody fingers:(
Thanks in advance
JoeFlannery
Occasional Contributor III
michaelcollins1
I used model builder to generate this Python code. I can't see dragging 2000 shape files into Model Builder at once (if you can, please let me know how). I used the tool "Define Projection" under Data Management Tools\Projections and Transformations.
My programming skills are not great, perhaps someone can come up with a loop.
# Projections.py
# Created on: 2011-06-23 09:23:57.00000
#   (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy
# Local variables:
Rivers = "C:\\Folder\\Rivers.shp"
# Process: Define Projection
arcpy.DefineProjection_management(Rivers, "PROJCS['WGS_1984_UTM_Zone_39N',GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',51.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]")
JoeFlannery
Doesn't seem like much of a burden to double-click the Batch Projection script tool in ArcToolbox, hit the find data Folder button, highlight as many featureclasses as you wish, answer a few more parameter questions and hit the OK button.  It works great and you don't need to write any code.
HartmutJunge
Hi Joe,
thanks for the fast answer and this nice idea, but....
unfortunately is there no input coordinate system and I got the message:
execution failure, parameter not valid
ERROR 000517: The coordinate system is not defined for the input dataset.
and: the tool expect a existing output database (.mdb). I created a empty acess mdb-file(because in the hole project isnt one)
Sorry for stupid questions, Iam not GIS expert, only user....in the meantime i will try with the other tools, but if you have another good idea.....
thanks
Hartmut
HartmutJunge
OK, I got it!!
Toolbox-Samples-DataMangement-Projections-BatchDefineCoordinateSystems-and finish!
Thanks again
