Save function from Image Analysis Window in mxd
737
06-22-2011 06:46 PM
JonKwong
New Contributor III
I created several new layers using the Clip and Mask functions in the Image Analysis window and then save the mxd.
When I move/copy the mxd and the source image to another machine, the layers are broken.
The broken layers reference to the .afr files in the temp directory. However, when I check the temp directory, the .afr files are missing.
Is there a way to save these layers in the mxd without breaking the path?
Or can I save these .afr to a different location?
