Adding XY Data from Excel
85058
34
06-21-2013 07:18 AM
JenniferRamey
I am new to ArcGIS and have been to the basic courses but I'm not understanding how to get my Excel spreadsheet into my Arcmap. I have created a spreadsheet that has longitude and latitude decimal format that I am wanting to be able to plot on my map.  I can get the data into the map but it does not appear to be plotting correctly.  My X axis is my long and my Y axis is my lat, I have the coordinate system set.  Please help.
RyanMcDermott
MBoucher21, thanks for the response.  I changed the format that my data was in to the xls format.  I am still running into the same problem of when I add the X,Y data I don't get any information in the x or y field drop down menus.  Any ideas?
michaelcollins1
you should probably convert the coordinates to decimal degrees first
DarrenWiens2
MVP Honored Contributor
In fact, you must convert to decimal degrees (or another number-only format) first. The dropdown lists only populate for numeric fields. When you bring Excel spreasheets into ArcMap, it assumes the datatype for each field. Since your lat/longs are in D/M/S it sees non-numeric characters, so it must be text.
As a side note, you must remove special characters and spaces from spreadsheet column names before importing into ArcMap.
MarkBoucher
In Excel, you can define a named range for the data or define the headings on the columns. Not sure if you have to do this or not. It has has been a while since I've done this and I don't have time to test my suggestion out right now.
MarkBoucher
  This is correct. Spaces can't be in the names. Use the "_" character.
jamiefenton
Not sure of your location, just browsing, do you have a "-" in front of your longitude (i.e. -96.5258)? This is necessary where I am.
IQBALZULKAFLI
Hallo sir.I'm new here. I also had some problem with my excel data.my data in decimal degree.once it been add to ArcGis 10.1 and want to display the X and Y, only one coordinate shows.thus this thing comes from my excel data? what I need to do.thank you for all your helps
ReneePardee
I was having this problem too. My points were ending up in the middle of the ocean. Then I watched this video, and I finally understood the problem. Don't forget that choosing a projection verses geographic coordinate system is critical. Projected uses meters and the geographic uses decimals for lat and long.
ArcGIS 10 - ArcMap - Projection and Coordinate Systems - YouTube
JoeBorgione
Not exactly-  it depends on the units used in the projection.  UTM are typically meters:  StatePlane in the U.S are typically feet.
While this is an older post, something that people often forget is when adding XY Longitude Latitude pairs is they need to add a - (minus) to the the longitude value when the data is in the western hemisphere.  (Let's not forget the G [eography] in GIS...)
ReneePardee
Well, sure it is slightly more complicated than I put it, but my data did have minus signs, and it was formatted properly, thus I was pulling out my hair. I was trying to use projected > UTM > WGS 1984 zone 13n, but the data would not cooperate. Using the geographic> World> WGS 1984, fixed my issue. It is a quick fix  that might help others.
