ArcMap layers and colors to AutoCAD or text file
2860
01-25-2011 12:56 PM
RayThompson
I am running:
Windoze 7
ACAD Map 3D 2010
ArcGIS 10
In the process of developing a set of geological mapping standards which will be usable in ArcGIS, ACAD and CorelDraw along with other programs that we use, I have been attempting to export a list of colors from a geological formation layer in Arc. There are ~20 formations in the layer and I was hoping to avoid the necessity of manually determining the RGB color code for each. I was able to add layer and color columns to the attribute table, but I am unable to populate the color column with the colors in the map.
TIA,
Ray
DavidCotton1
Long shot... Hi did you ever resolve this as I too need to do exactly the same ?
