ArcSDE 10 for Oracle on Linux : Listener Configuration Problems
2444
07-27-2012 06:23 AM
DavidJacques
We have 2 ArcSDE 10.0 services on Red Hat Linux 5 set up on the same server. (Server "A")
We have 2 Oracle instances also the same server (Server "A")
    1 is 10g (10.2.0.4.0) seabed_sde
    1 is 11g (11.2.0.1.0) corp_sde
(A 3rd Party application we need uses  the seabed_sde service and the highest supported RDBMS is Oracle10g.
  Otherwise we would have had both instances be 11g).
Everything was running fine (so it seemed), until I attempted to use st_geometry calls via SQL plus on the 11g (corp_sde) service.
Is there any way to configure the Oracle listener (extProc) so that st_geometry calls to both ArcSDE 10 services will work ?
TravisVal
What's the error that you are getting when you attempt to use st_geometry with your 11g service.
I am assuming that you have two homes, do you also have two listeners?  Do you have both these services trying to access the same ST_ShapeLib.dll?
DavidJacques
We have two homes, one listener.  .
The standard check sql statement from the documentation....
select SDE.ST_Geometry('point(-94.550851 27.833014)',4) from dual;
produces this...
ORA-06520: PL/SQL: Error loading external library
ORA-06522: libclntsh.so.11.1: cannot open shared object file: No such file or directory
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 12
ORA-06512: at "SDE.ST_GEOMETRY", line 55
06520. 00000 -  "PL/SQL: Error loading external library"
*Cause:    An error was detected by PL/SQL trying to load the external
           library dynamically.
*Action:   Check the stacked error (if any) for more details.
TravisVal
You should be able to set up two different entries into you listener.ora file.  Here is an old Oracle thread that I found on it.
https://forums.oracle.com/forums/thread.jspa?threadID=109698&tstart=2160
I would try setting up the 10g extproc first, and then trying to set up the 11g extproc through the hs\admin\extproc.ora file.  I don't know if that will work through.  You may have to set them both up through the listener.
Let us know how it goes.
