Calculate (plus) multiple fields
3606
6
11-23-2015 07:33 AM
CarlosHernandez8
I have problems to calculate (plus) multiple fields in armap. It is normal? any solution?
DarrenWiens2
MVP Honored Contributor
As Richard Fairhurst​ indicates, you can get as this with a fairly compact Python code block:
def calc(*args):
  return sum(i for i in args if i is not None) # loop through all arguments in function, adding if not 'None' (i.e. null)
Your expression would be something like below (listing all desired candidate fields):
calc (!Field1!, !Field2!, ..., !Fieldn!)
JoeBorgione
Perhaps you could be a little more specific and provide details of what you are trying to accomplish.
RichardFairhurst
Post the calculation you used.  Did you build the expression using the expression builder field list?  Are you sure all of the fields are Double, Float, Long or Short fields?  Is the output field the correct type to hold the addition result (typically you should use either a Double or a Long output field).  Are there Null values in the fields you are adding together?  Is the data source a shapefile/dbf file or a geodatabase feature class/table.  Is it an SDE database?  What version of ArcMap are you using?
CarlosHernandez8
Hi thanks for answering,
all fields are double,
the output field is double,
there are null values in the fields,
I'm doing it on a feature class (geodatabase)
armap version 10.3
Calculo:
[PSB_01_V_AÑO]+ [PSB_05_V_AÑO]+ [PSB_03_V_AÑO]+ [PCC_01_V_AÑO]+ [PCC_02_V_AÑO]+ [PCC_04_V_AÑO]+ [PCC_05_V_AÑO]+ [PAM_01_V_AÑO]+ [PAM_02_V_AÑO]+ [PAM_03_V_AÑO]+ [PCE_01_V_AÑO]+ [PCE_02_V_AÑO]+ [PCE_03_V_AÑO]+ [PCE_04_V_AÑO]+ [PCE_05_V_AÑO]+ [PCE_07_V_AÑO]+ [PRE_01_V_AÑO]+ [PRE_02_V_AÑO]+ [PRE_03_V_AÑO]+ [PSP_01_V_AÑO]+ [PSP_02_V_AÑO]+ [PDSP_01_V_AÑO]+ [PDSP_2_V_AÑO]+ [PDSP_3_V_AÑO]+ [PFPS_2_V_AÑO]+ [PFPS_3_V_AÑO]+ [PFPS_1Y4_V_AÑO]
RichardFairhurst
You cannot add Null values with other values.  See Fezter's answer to this post for a Python method you should be able to adapt to your problem.
DarrenWiens2
def calc(*args):
DanPatterson_Retired
Or as documented in this link Before I forget ... # 18 ... Those pesky <null> things...
for a pythonic approach
