There isn't much of an issue using this for a simple feature class, but if you use versioning
or complex behaviors in feature datasets you may run in issues. ArcSDE used to use simple
sequences, but the performance was sufficiently slow with bulk loading that the current
"sequence and pipe" mechanism replaced it.
- V
