Cannot edit file geodatabase
3730
07-12-2010 04:10 PM
JackLau
New Contributor III
For some reason I cannot edit my file geodatabase.  If I try to start editing, I get the following message:
Could not edit file in folder or database you selected.
Check to see you have appropriate permission.
Any idea why this would happen, It's a file that I created orignally.
Thanks for any suggestions.
DerekLaw
Esri Esteemed Contributor
Hi Jack,
In Windows Explorer, right-click on the File geodatabase file (e.g., [nameofgeodatabase].gdb) > Properties. Verify that it is not set to be "read-only".
Hope this helps,
