Cannot Insert Features when Exporting Feature Class
3618
10-15-2014 08:21 AM
JenniferDick
New Contributor II
Hoping someone could provide some help...
I'm exporting a features class into a new clean File Geodatabase (there are no other feature classes in the geodatabase). I've tried this process multiple times but continue to receive ERROR: 000224 'Cannot Insert Features' I don't understand what could be causing this issue.
Any assistance would be greatly appreciated
Thanks
Jenn
denisedavis
Occasional Contributor III
Try using the import option from the geodatabase you've created through the catalog.
JenniferDick
New Contributor II
Thanks Denise, I'll will try that right now
JenniferDick
New Contributor II
Hi Denise,
Still receive the same error when running the process as you suggested.
Any more thoughts? Do you need more information from me?
Thanks
Jenn
denisedavis
Have you tried exporting to a shapefile and importing the shapefile to the geodatabase? Are your coordinate systems the same in the geodatabase and the feature class?
