classify rasta
2518
10-31-2015 01:45 AM
charlotteJunker
Hello,
I've got a satellite Picture and I've classified it:
Now I'd like to create a single layer for each class (kurz, mittel, lang). I've tried to use the raster calulator, but I don't know how to export the classes.
Thanks!!
Tags (1)
DanPatterson_Retired
in generic terms..
gridname  equals class  (mygrid = someclass)
then save the result as usual
JayantaPoddar
MVP Esteemed Contributor
Hello Charlotte,
Let's say the GridValue of kurz = 1, mittel = 2 and lang = 3
Then, in Raster Calculator,
For Kurz raster dataset,
("value" = 1)
For mittel raster dataset,
("value" = 2)
For lang raster dataset,
("value" = 3)
N.B.: The above expressions should be written in 3 different instances, NOT as a single expression.
Let us know if your requirement is different.
Think Location
DarrenWiens2
MVP Honored Contributor
Make sure you use == in Raster Calculator. For example, "YourRaster" == 1
curtvprice
What are you going to do with the layers?  This may help us give you a better answer.
JoeBorgione
Here are a couple of different Rasta classifications I found with a google search:
Image result for rasta
That should just about do it....
