Converting Polylines to Polygons
1275
09-13-2011 01:35 AM
clairetaylor
I have an attribute with 100+ closed polyline features (Oil prospects) and I need to convert them to polygons. Is there an easy way to convert from polylines to polygons? I do not want to have to trace the original polylines to create new polygons as this is very slow.
Claire
DanLee
by Esri Regular Contributor
Depending on how the closed polylines are spatially related to each other, Feature To Polygon tool might do what you need, if the polylines are not crossing each other.
myname
it's here clip help you convert polylines to polygon in arcgis convert lines to polygon in ArcGIS - YouTube
