Well, I ****** up on a projection and I can't seem to get it back so I decided to use an older set of data. Everything is the same except a couple of columns of data. Fortunately I can use the field calculator on most of it but there's one column I would like to copy from the old layer to the other. I was thinking I could use the join field tool but I'm not sure if there's a way to copy the same records to the other.
The table looks like this.
Field A | Field B |
<Null> | <Null> |
<Null> | FTTH |
<Null> | FTTH |
<Null> | <Null> |
<Null> | FTTH |
<Null> | <Null> |
<Null> | <Null> |
So how to I copy the fields from B to A by keeping the Fields in B the same on A.
Thanks!
~alex
Message was edited by: Dan Patterson An inadvertant potty mouth slip removed. Always run swear-check
