Copying Archived Layers from One Server to Another
451
08-27-2012 01:20 PM
MichaelTodd
I am trying to copy a layer from a server running SDE 10.0 (on SQL Server 2005) to a server running SDE 10.1 (on SQL Server 2012). The layer has versioning and archiving enabled and there does not seem to be a way to copy the archival information.
Is there a way to copy the layer and all archiving information as well?
MichaelTodd
Per ESRI:
"It would not be possible to retrieve the same archival information after exporting the feature class into a new geodatabase."
So, in other words, one cannot copy archival information from one geodatabase to another. It must always live in the same geodatabase. Once you have transferred a layer to a new geodatabase you can set up versioning and then archiving, but you're essentially creating a _new_ archive that starts from the data that you created it.
If you need to retain archival information when moving to a new ArcGIS version and a new server, the recommended course of action is to:
1. Upgrade the geodatabase to the new version
2. Backup the database
3. Restore the database on the new server
That should ensure that everything is retained during the move.
MichaelTodd
Per ESRI:
