Could not start ArcSDE -- Check Network, $SDEHOME disk, DBMS settings
3440
8
11-16-2010 12:20 PM
VadivelanPalanichamy
I am new to ArcSDE.   We have ArcSDE 9.3 (windows 2003) running in dev/qa/prod pointing to oracle 10g spatial.
I am trying to install sde in my local machine (windows xp).   I have got the following steps from the person who installed in the dev/qa/prod machines.
1) sdesetup -o upgrade -d ORACLE10G -u sde -p sde -i esri_sde
2) sdeservice -o create -d ORACLE -n -p sde -i esri_sde -u domain\username -P pwdWord
3) Now go to : C:\ArcSDE\ora10gexe\etc
   Open DBInit.sde.
   Replace the existing text with :
   set LOCAL=xy_darc
4) Now start the sde service:
   sdemon -o start
   password : sde
After step 4) I am getting Could not start ArcSDE -- Check Network, $SDEHOME disk, DBMS settings and dbinit.sde.
Any help/ideas on this.
ZachWalker
Im having a similar issue.  Did you get this resolved?
JonHall
Occasional Contributor II
have you checked the logs in \Program Files\ArcGIS\ArcSDE\sqlexe\etc\ ?
HelenYang
Can you connect from your machine to the oracle database using sql?
Yes, I am able to connect the oracle database using Oracle SQL developer............
any help on this.
vadivelan. p
I installed in Windows 2003.. no issue in starting the service..  It seems it is OS problem.
I have seen in the ArcSDE supported OS.. windows xp is not listed.
VinceAngelo
Esri Esteemed Contributor
I'm running 9.2sp6, 9.3.1sp2, and 10.0sp1 on an XP host without difficulty.
Perhaps you're not using SP3 with all the roll-up patches?
- V
ForrestJones
Hi vadivelan,
You might want to check the $SDEHOME\etc\sde_<sdeservicename>.log and giomgr_<sdeservicename>.log.
Those should have some more information that might help.
