Create Mosaic Dataset
745
04-27-2017 10:43 AM
MikaelBauner
Hello I wonder which settings / coordinate system I should use when import photos  from UAV DJI Phantom 4 in a Mosaic Dataset(Create Mosaic dataset)? I have test WGS 84 but error...
forestknutsen1
MVP Regular Contributor
What format are the source rasters in? tif?
What coordinate system are the source rasters it?
What system you select for the mosaic depends in part on what you want to do with it. If it is a small area and just want to look at it in Arc and you are in the US I would go for the state plane system of the image area...
What is the error message?
MikaelBauner
Raster in JPEG format
DJI Phantom standard output coordinate system (part of my question).
Ok state plane system.. so in Sweden it´s WGS_1984_UTM_zone_33?
forestknutsen1
http://tech2mine.maps.arcgis.com/apps/Solutions/s2.html?appid=ef12074d67f648a7825cc7ed160d68fa
Yes. Looks like Sweden falls within a few UTM zones. With most of it zone 33.
Unfortunately, I don't know anything about the drone you are using. You will definitely need to know the system of the source rasters from the drone. I would think that the output system would be in the documentation some place. What happens if you just display one of the images in arc? Is that working ok?
