Hi All,
I'm working with Oracle 11.2, ArcSDE 10.1 and ArcGIS 10.1 and I have created multiple enterprise geodatabase from Arc Catalog. It means I have 10 enterprise geodatabase and one SDE enterprise geodatabaseall, all have its own user administrator.
My requirement is, I have to separate the index tablespace and data tablespace by editing DBtune file for each enterprise geodatabase.
In case of SDE, there is no problem I can export and import the edited dbtune file. But in case of other 10 Enterprise geodatabase only export command is working, if I want to import edited dbtune file using sdedbtune command it gives me error "insufficient privileges".
Need an expert advice. Please its urgent.
Thanks in Advance
Amit
