DBTune parameter on Multiple Enterprise Geodatabase ArcSDE 10.1
516
03-14-2013 07:09 PM
AmitGupta
Hi All,
I'm working with Oracle 11.2, ArcSDE 10.1 and ArcGIS 10.1 and I have created multiple enterprise geodatabase from Arc Catalog. It means I have 10 enterprise geodatabase and one SDE enterprise geodatabaseall, all have its own user administrator.
My requirement is, I have to separate the index tablespace and data tablespace by editing DBtune file for each enterprise geodatabase.
In case of SDE, there is no problem I can export and import the edited dbtune file. But in case of other 10 Enterprise geodatabase only export command is working, if I want to import edited dbtune file using sdedbtune command it gives me error "insufficient privileges".
Need an expert advice. Please its urgent.
Thanks in Advance
Amit
TravisVal
New Contributor III
Can you post the command you are trying to use?
It worked for me using the following:
sdedbtune -o import -f ..\etc\dbtune.sde -u sde2 -p *** -i sde:oracle11g:myserver/orcl:sde2
Travis
AmitGupta
Thank you very much Travis.
Your reference code is working and I can import modified dbtune file for another user. Actually i was forgetting to add full service name path -i sde:oracle11g:myserver:user.
Once again Thank u very much for your support.
Amit
TravisVal
New Contributor III
Your welcome, I am happy I was able to help.
Travis
