Deleting Feature Classes from File Geodatabases
3179
10-10-2012 07:43 AM
RyanFonzi
I cannot delete unwanted feature classes from my file geodatabase using ArcGIS for Desktop Advanced 10.1.  No one else is accessing the data and I get error messages saying I cannot delete.  Does it have something to do with the lock files?  Please help.
KevinDunlop
Can you make other changes to that FGDB which an attribute update or create new features?
RyanFonzi
Yes, I am able to create new feature classes, edit the data and import and export into the GDB.  It just won't let me delete anything.
AoifeHealy
I'm having the same problem. I misspelled a column name when importing a new feature class and because the column heading was wrong the relevant data did not get imported to the table. I can't rename the column heading or delete the feature class to start again.
Any ideas?
Thanks a million,
Aoife
