We are attempting to use arcpy.DisconnectUser before running a nightly compression of a geodatabase. But when running arcpy.DisconnectUser, we are intermittently receiving an error stating that the connection information provided was for a non-administrative user. The geodatabase uses dbo-schema and we have confirmed that the geodatabase administrator is a member of the sysadmin server role.
Our SDE maintenance scripts fail periodically due to this issue similar to this post: https://community.esri.com/thread/180900. SDE is running v10.3.1 with a SQL Server 2012 back-end. The script runs from a VM that has ArcGIS 10.4.1 installed.
