sdelayer -o register -l test,geom -e p -t geography -R 1 -i sde:sqlserver:localhost,1276 -D <%databasename%> -E -180,-90,+180,+90 -u <%user%> -p <%password%> ArcSDE 10.0 for SQL Server Build 685 Fri May 14 12:05:43 2010 Layer Administration Utility ----------------------------------------------------- Error: Attribute conversion error (-55). Error: Unable to create registration for table test.
When you create a feature class or table in ArcGIS, there are 11 possible data types you can assign to a field. That means there are some data types that can only be created outside ArcGIS.
