Error connecting to address locator....
571
09-21-2010 11:52 AM
SherrieTaylor
I've upgraded to 10, in spite of my reservations, and I've installed the service pack, but yet I keep running into strange errors.  I've been able to geocode using a NAVTEQ address locator without a problem until yesterday.  All of a sudden I'm getting the error, "Failed to connect to database.  An underlying database error occurred.  System resource exceeded." when I try to "add" the NAVTEQ locator.  My address locator is fine and my machine is well within the computing requirements and I have plenty of RAM etc. so I'm at a loss as to what else to do.  Anyone have any ideas?
BruceHarold
Hi Sherrie
It sounds like you should log a support call so an analyst can reproduce your issue.  Existing locators should work fine in ArcGIS 10.  One (remote) possibility is your existing locator did not have reference data stored in it and the connection required to wherever the data resides cannot be made for some reason.
Regards
