Extract multiple raster by mask automatically
4195
7
09-20-2019 08:23 AM
gianguyen
Hi Community,
I am working with a project where I have to extract 3650 rasters. It will take forever to get it done manually.
I am thinking about using ArcPy or Modelbuilder to do it automatically.
Can you help me with this?
Thank you so much
Gia Nguyen
George_Thompson
Esri Frequent Contributor
I would look at this GP tool and you can batch it in Model Builder - Extract by Mask—Help | ArcGIS Desktop or write Python to iterate through and do the process.
--- George T.
PavanYadav
Alternatively you can use the Clip Raster—Data Management toolbox | ArcGIS Desktop tool. But it all depends on your need. The Clip Raster tool is bit different from the the Extract by Mask tool. The Clip Raster tool cuts out a portion of a raster dataset (extent changes) while Extract by Mask tool does not change the extent of the raster but converts values outside of the clip feature/raster to NoData.
here is one example:
import arcpy
import os
workspace = r"D:\test\Stowe.gdb"
arcpy.env.workspace = "D:\test\Stowe.gdb"
fc = r'D:\test\Stowe.gdb\clip_feature'
desc = arcpy.Describe(fc)
xmin = desc.extent.XMin
xmax = desc.extent.XMax
ymin = desc.extent.YMin
ymax = desc.extent.YMax
rectangle = str(xmin) +' '+ str(ymin) +' '+ str(xmax) +' '+ str(ymax)
rasters = []
walk = arcpy.da.Walk(workspace, datatype="RasterDataset") #
for dirpath, dirnames, filenames in walk:
    for filename in filenames:
        print(filename)
        rasters.append(os.path.join(dirpath, filename))
for raster in rasters:
    arcpy.Clip_management(raster, rectangle, raster + "_clip")
gianguyen
Hi Pavan Yadav,
I appreciate your suggestion. It is very helpful.
I got another issue. I want to convert multiple NetCDF files to rasters
using ArcPy or Python.
Here is the code for a NetCDF file that I learned from ESRI. Can you help
me to edit it to read convert multiple file?
Thanks
  1. Import system modules
import arcpy
  1. Set local variables
inNetCDFFile = "C:/data/netcdf/rainfall.nc"
variable = "pptx"
XDimension = "lon"
YDimension = "lat"
outRasterLayer = "rainfall"
bandDimmension = ""
dimensionValues = ""
valueSelectionMethod = ""
cellRegistration = ""
  1. Execute MakeNetCDFRasterLayer
arcpy.MakeNetCDFRasterLayer_md(inNetCDFFile, variable, XDimension,
YDimension,
outRasterLayer, bandDimmension,
dimensionValues,
valueSelectionMethod, cellRegistration)
PavanYadav
Hi gia nguyen
To filter *.nc files only please try, the following:
ncFiles = []
workspace = r"D:\test"
#datatype limits the results returned. See supported datatypes:
#Walk—Help | ArcGIS for Desktop.
walk = arcpy.da.Walk(workspace)
#NC is not a supported datatype so filtering like this: "if filename[-3:]=='.nc'"
        if filename[-3:]=='.nc':
            ncFiles.append(os.path.join(dirpath, filename))
gianguyen
Hi Louise Thank you for your response. While waiting for the best solution,
I tried the code below. It works still now. I use it to convert from NetCDF
files to rasters.
import arcpy
from arcpy import env
from arcpy.sa import *
Input_Temp_folder = "E:\Mekong\DATA\JMP_Deeplearning_data\Mekong_temp\Temp_2017"
Out_Temp_folder_Max
="E:\Mekong\DATA\JMP_Deeplearning_data\Mekong_temp\Temp_2017\Max"
Out_Temp_folder_Min
="E:\Mekong\DATA\JMP_Deeplearning_data\Mekong_temp\Temp_2017\Min"
arcpy.env.workspace = Input_Temp_folder
arcpy.env.overwriteOutput = True
arcpy.env.scratchWorkspace = Out_Temp_folder_Max # Create scratch workspace
arcpy.env.scratchWorkspace = Out_Temp_folder_Min # create Scratch workspace
variableTemp1 = "T2MMAX"
variableTemp2="T2MMIN"
XDimension = "lon"
YDimension = "lat"
time = "time"
NetCDFfiles = arcpy.ListFiles("*.nc4.nc")
print NetCDFfiles
for filename in NetCDFfiles:
print ("Processing: " + filename)
day = filename[27:35]# extract date in the filenames
outRasterLayer_Temp_Max = variableTemp1 + "_" + day # create a
time series for names
outRasterLayer_Temp_Min = variableTemp2 + "_" + day # create a
InNetCDTemp = arcpy.env.workspace + "/" + filename # get a file
arcpy.MakeNetCDFRasterLayer_md(InNetCDTemp, variableTemp1,
XDimension, YDimension, outRasterLayer_Temp_Max,time)
arcpy.MakeNetCDFRasterLayer_md(InNetCDTemp, variableTemp2,
XDimension, YDimension, outRasterLayer_Temp_Min,time)
outRasterTemp_Folder = Out_Temp_folder_Min
arcpy.SplitRaster_management
(outRasterLayer_Temp_Max,Out_Temp_folder_Max,outRasterLayer_Temp_Max,"POLYGON_FEATURES","TIFF","NEAREST","","","","DEGREES","","","Mekong_Basin","","","")
(outRasterLayer_Temp_Min,Out_Temp_folder_Min,outRasterLayer_Temp_Min,"POLYGON_FEATURES","TIFF","NEAREST","","","","DEGREES","","","Mekong_Basin","","","")
gianguyen
Thank you for your suggestions. They are very useful.
Besides, I also found a tool SAMPLE which can extract value from rasters (single/multi bands) into a grid (fishnet).
Again, thank you so much
PavanYadav
I'm glad you find it useful.
Regards,
Pavan
