Feature class/shapefile dependencies
1122
10-06-2016 02:47 PM
BradBurford
New Contributor II
I am working with ArcGIS Pro 1.3, as well as ArcGIS 10.4. Is there a tool that will find dependencies for a selected feature class or shapefile? For example, I would like to be able to select a feature class and a project file location (folder/sub-folders) and return the project files that reference the selected feature class, with results looking something like
Feature Class xyz is referenced by d:\myProject.mxd
DanPatterson_Retired
No... there are tools by others, that allow you to examine featureclasses and return the projects, etc, that are used by them.
DarrenWiens2
MVP Honored Contributor
You can do it using Python:
>>> import os
... workspace = r'C:\junk' # starting directory
... lyr_dict = {} # empty dictionary
... for root, dirs, files in os.walk(workspace, topdown=True): # starting traversing directories
...     for file in files: # loop through file names
...         if file.endswith('.mxd'): # if it's an mxd
...             mxd = arcpy.mapping.MapDocument(os.path.join(root,file)) # make map object
...             lyrs = arcpy.mapping.ListLayers(mxd) # list layers
...             for lyr in lyrs: # loop through layers
...                 if lyr.supports('dataSource'): # if the layer supports dataSource property
...                     lyr_dict.setdefault(lyr.dataSource,[]).append(mxd.filePath) # add to dictionary‍‍‍‍‍‍‍‍‍‍‍
The above script creates a dictionary like {layer_path1:[mxd,mxd,mxd...], layer_path2:[mxd,mxd,mxd...]...}
RebeccaStrauch__GISP
Hi Darren, nice script....adding it to my toolset.  I did make one addition on line 10 to eliminate some "false positives" which may be groups or some other type which grabs lyr.dataSource that are "empty/blank".  In my test, it was found in all the mxds and therefore mucked up my results.  I haven't tested it further (and there may be a better test), but this worked for my purposes......changing line 10 to
if lyr.supports('dataSource') and (len(lyr.dataSource) > 0) : # if the layer supports dataSource property but NOT zero length
