Feature Compare toolbox question
636
03-24-2017 10:07 AM
PROBERT68
I have a question for you all.
So, I want to compare between the dataset I have to check for each feature. My question here is what is "Input Base Features" and "Input Test Features" ?  Why didn't ESRI put the Original Data vs the New Data  instead ? It just helps to less confuse and claify.
I need to run MUID to check for compare to see if they both run the same name .
Thanks !
BTW, I am reading here Feature Compare—Help | ArcGIS for Desktop
So that helps but I want to know the difference between Input Base and Test Features ?
IanMurray
The helps tells you exactly the difference.
The Input Base Features are compared with the Input Test Features. Input Base Features refers to data that you have declared valid. This base data has the correct geometry definitions, field definitions, and spatial reference.
The Input Test Features are compared against the Input Base Features. Input Test Features refers to data that you have made changes to by editing or compiling new features.
PROBERT68
So the declared valid means the data is the new data and the Input Test Features is the old data ?
DanPatterson_Retired
Known quality vs unknown quality
