File Geodatabase coded domain not recogized by ArcGIS Online?
3392
04-26-2015 10:56 AM
YukunXing
New Contributor III
I created a File GDB and set up a domain, and the domain was assigned to a field in a feature class. The domain behaves as expected on in ArcGIS Desktop (dropdown list when editing the content of that field).
But if I zip up the FGDB and upload to ArcGIS Online to created a feature layer and edit the layer online, there is no dropdown when editing.
I don't see any additional step in this tutorial, other than a different mechanism of getting data to ArcGIS Online. I don't think I can do it the same way in ArcGIS 10.0: http://doc.arcgis.com/en/collector/android/create-maps/prepare-data-desktop.htm
Anyone has any idea what's going on? Thanks!
YukunXing
New Contributor III
Never mind. It looks like uploading the zipped FGDB is why coded value domain doesn't automatically translate to dropdown. I found a 10.1 Desktop and published the service from ArcMap "Share As --> Service" and it worked.
YukunXing
New Contributor III
