Solved! Go to Solution.
If you have an Advanced license, Tabulate Intersection will tell you everything you need to know and more.
Thanks bixb0012
I am using ArcGIS for Desktop 10.3 standard version, the Tabulate Intersect tool seems to be very useful, the challenge is because i don't have the Advanced licence .
Take a look at the Find Overlapping Features tool
Thanks Ken Buja
I have download and install it and it is listed in the addin manager. If I go to customize and choose commands I can follow the path of Biogeography Tools and I can see the tool there. From there I have not been able to figure out how to actually use it.
From there you drag the command to an existing toolbar. Once you exit the Customize dialog, the tool is available.
Adding a command to a toolbar or the main menu—Help | ArcGIS Desktop
How can I change the FID to OBJECTID???
I need to transform these numbers into primary key FID
Thks in advance!
