Just downloaded the GDBT tool for ArcGIS version 10. Found two issues as describing below. Please help to identify the issue and how to fix the missing ocx error. Thanks!
1. the install.bat script has problem when trying to register the SDEUtilSvr10.dll. I can fix this error by adding quotes to the file name.
2. After successfully run the install.bat, click the GDBT tab in ArcCatalog, I got the error complaining the missing file mschrt20.ocx.
My env: XP SP3. ArcGIS 10. MS .NET Framework 3.5 SP1 and 4
The following is the list of the result:
ArcGIS Desktop 10
ArcGIS 10.0 (Desktop, Engine, Server) Geodatabase Replication Upgrade patch
ArcGIS 10 Desktop Raster Format Patch
ArcGIS 10 Desktop Add Globalids in ArcView Patch
ArcGIS Desktop 10 File Menu Performance Patch
ArcGIS ArcReader 10
ArcGIS Server 10 - GIS Services
ArcGIS 10 Server Raster Format Patch
ArcGIS Server 10 - Web Applications
ArcObjects SDK for the Microsoft .NET Framework 10.0
ArcGIS VBA Resources 10.0
ArcGIS License Manager 10
ArcGIS Desktop 10 Tutorial Data
ArcSDE for Microsoft SQL Server 10
ArcSDE 10.0 General Update Patch for SQL Server
Data Interoperability Extension 10.0
ArcGIS Desktop Case Tools Extension 10.0
ArcGIS Explorer 1200
