I am in Canada and have a table of addresses that I am trying to geocode. In the past I had not had any difficulty creating a locator service using a road network file that identified the address ranges for the left and right side of individual street segments.
I've created a new address locator using the dual range style based on a road network file that seems to match up well with the builder (it correctly identifies the fromleft, toleft, fromright, toright fields, as well as the streetname).
After building it, then I try to use it with a table that has the address data with house number, streetname, street type in separate fields, and also together. However when I try to use the address locator the input field name showing on the left is streets.
Then when I run it, nothing gets placed. I've changed the zone setting, and nothing.
Any suggestions?
