Hide system tables from SDE schema
5995
20
04-09-2010 05:53 AM
NathanielWingfield
I recently installed ArcSDE 9.3 on Oracle 11g. No less than 119 system tables from the APEX_030200 and ORDDATA schemas are showing up in ArcCatalog. Is there an easy solution to make these go away?
VinceAngelo
Esri Esteemed Contributor
Don't grant SELECT to PUBLIC on these other schemas
- V
NathanielWingfield
This is a stock Oracle install; I have not explicitly granted anything to PUBLIC. I can revoke the privileges but I'm not sure what implications that may have.
Besides, the PUBLIC user has SELECT privileges on 2,143 database objects in 13 schemas. How come these 119 objects are visible, but not the others? Some explanation of the underlying mechanics would be helpful. Thanks.
JimDickerson
I also have this problem.  I used Enterprise Manager to edit user Public's Object Privileges.  I deleted a few and reconnected via ArcCatalog but they are still showing up.  Like nwingfield, I don't know what will happen if I delete them all.
MonikaFlach
We also have this problem.
see attachement
StephenLewonka
Similiar problems for me.
here is the query ArcCatalog issues (with a little editing from me for clarification purposes).
I've just installed Apex 4.0 and many (tho not all) my APEX obects are showing.
so the APEX 4.0 schema would be apex_0400000 and APEX 3.2 schema is apex_030200..  both of these aren't filtered out with this query.  I think you have to go back to APEX 3 where it was called "FLOWS_030000" (AC.owner != 'FLOWS_030000') for it not to show.
there should be a way to modify ugly piece of hardcoding.
SELECT AC.owner, AC.table_name
FROM ALL_CATALOG AC
WHERE
AC.owner != 'MTSSYS' AND
AC.owner != 'SYS' AND
AC.owner != 'SYSTEM' AND
AC.owner != 'PERFSTAT' AND
AC.owner != 'DMSYS' AND
AC.owner != 'EXFSYS' AND
AC.owner != 'WK_TEST' AND
AC.owner != 'PUBLIC' AND
AC.owner != 'SYSMAN' AND
AC.owner != 'SI_INFORMTN_SCHEMA' AND
AC.owner != 'MDSYS' AND
AC.owner != 'ORDSYS' AND
AC.owner != 'FLOWS_030000' AND
AC.owner != 'FLOWS_FILES' AND
AC.table_type != 'SEQUENCE' AND
AC.table_name != 'RASTER_COLUMNS' AND
AC.table_name != 'RECONCILED_STATES' AND
AC.table_name != 'SDE_UUID_TEMP$' AND
AC.table_name != 'SDO_GEOM_METADATA' AND
AC.table_name NOT LIKE 'F%_SQL_IX1_%' AND
AC.table_name NOT LIKE 'S%_IDX$' AND
AC.table_name NOT LIKE 'S%_PX$' AND
AC.table_name NOT LIKE '%_IX1_%$' AND
AC.table_name NOT LIKE '%_F%$' AND
AC.table_name NOT LIKE '%_H%$' AND
AC.table_name NOT LIKE '%_RT$%' AND
AC.table_name NOT LIKE '%_SDOLAYER' AND
AC.table_name NOT LIKE '%_SDODIM' AND
AC.table_name NOT LIKE '%_SDOGEOM' AND
AC.table_name NOT LIKE '%_SDOINDEX' AND
AC.table_name NOT LIKE '%RT_%$' AND
AC.table_name NOT LIKE '%QT_%$' AND
AC.table_name NOT LIKE '%BIN$%' AND
AC.table_name NOT LIKE 'SDE/_%' ESCAPE '/' AND
AC.table_name NOT LIKE 'DR$XML%' AND
AC.table_name NOT LIKE 'KEYSET_%' AND
AC.owner != 'AURORA$JIS$UTILITY$' AND
AC.owner != 'OSE$HTTP$ADMIN' AND
AC.owner != 'QS' AND
AC.owner != 'QS_CBADM' AND
AC.owner != 'QS_CS' AND
AC.owner != 'QS_ES' AND
AC.owner != 'QS_OS' AND
AC.owner != 'QS_WS' AND
AC.owner != 'WMSYS' AND
AC.owner != 'XDB' AND
AC.owner != 'WKSYS' AND
AC.owner != 'OLAPSYS' AND
AC.owner != 'RMAN' AND
AC.owner != 'ODM' AND
AC.owner != 'ODM_MRT' AND
AC.owner != 'DBSNMP' AND
AC.owner != 'OUTLN' AND
AC.owner != 'CTXSYS' AND
NOT (
AC.OWNER IN (SELECT instance_name FROM SDE.INSTANCES) AND
AC.table_name IN ('COLUMN_REGISTRY','GEOMETRY_COLUMNS','LAYERS','LOCATORS', 'METADATA','GCDRULES','MVTABLES_MODIFIED','SDE_LOGFILES', 'SDE_LOGFILE_DATA','SPATIAL_REFERENCES','STATE_LINEAGES','STATES', 'STATE_ID_GENERATOR','TABLE_REGISTRY','VERSION','VERSIONS', 'DBTUNE','LAYER_LOCKS','OBJECT_LOCKS','PROCESS_INFORMATION', 'SDE_TABLES_MODIFIED','STATE_LOCKS','TABLE_LOCKS','LINEAGES_MODIFIED', 'SERVER_CONFIG','SDE_XML_TAGS','SDE_XML_INDEX_TAGS','SDE_XML_INDEXES', 'SDE_XML_COLUMNS','SDE_LOGFILE_POOL','INSTANCES','ALL_ST_GEOMETRY_COLUMNS_V', 'ST_COORDINATE_SYSTEMS','ST_GEOMETRY_COLUMNS','ST_GEOMETRY_INDEX','ST_SPATIAL_REFERENCES', 'USER_ST_GEOM_INDEX_V','USER_ST_GEOMETRY_COLUMNS_V','ST_UNITS_OF_MEASURE')
ORDER BY AC.owner, AC.table_name
XianzhouLu
connect to oracle using sys as sysdba
then:
revoke all on apex_030200.apex_application_lovs  from public;
and so on.
chandesrisbasile1
It seems other people have found another solution:
http://forums.esri.com/Thread.asp?c=93&f=993&t=110733
Mark table as hidden in ArcSDE data dictionary
Author  Michael Mannion
Date  Nov 12, 2003
Message  Rodrigo,
You can set an ArcSDE table registry flag to mark a table as hidden, preventing it from being displayed in the ArcCatalog Contents tab. If a table is already registered with ArcSDE, use:
sdetable -o alter_reg -t [table] -H hidden
Alternatively, you can register an independent database table with ArcSDE using:
sdetable -o register -t [table] -H hidden
To facilitate setting this for multiple tables, you can use SQL*Plus to spool a new script. By concatenating literals with the variable table names, you can quickly generate a template script from which you can easily delete the tables you do not want to mark as hidden. Then, run the script, refresh ArcCatalog, and the tables should be absent from the Contents tab. Refer to the text below for an example.
Good luck.
-Michael
SPOOL hide_tables.sh
SELECT
  'sdetable '
  || '-o alter_reg '
  || '-t ' || table_name || ' '
  || '-H hidden '
  || '-u [user] '
  || '-p [password] '
  || '-s [server] '
  || '-i [instance] '
  || '-N'
FROM
  user_tables;
SPOOL OFF
   Michael Mannion
Mannion Geosystems, LLC
www.manniongeo.com
HelenYang
- V
I did as advised (eg. REVOKE SELECT ON APEX_030200.APEX_APPLICATION_LOV_ENTRIES FROM PUBLIC;). However, ArcCatalog still shows all the APEX objects in ArcCatalog list.
I even tried REVOKE all on xxxx from public. The tables are still showing in the ArcCatalog.
Wonder why?
ForrestJones
Hi All,
Are you using Oracle 11gR2 and a version of sde earlier than 9.3.1 SP2? This nim has been fixed in 9.3.1 sp2 to filter those tables...
NIM052156: Ora11gR2 APEX* & ORDDATA* tables need to be filtered
http://resources.arcgis.com/content/nimbus-bug?bugID=TklNMDUyMTU2
