How do I add units to geographical coordinates?
1454
08-05-2016 05:14 AM
BenColeman2
I have a dataset with imbedded geographical coordinates. I think the units for those coordinates should be "m", but instead of units they have a "??". Does anyone know how to tell a dataset what units its geographical coordinates should be in?
DanPatterson_Retired
JakeSkinner
Esri Esteemed Contributor
Hi Ben,
Can you provide more information?  For example, are you working with a feature class or shapefile?  When you refer to embedded coordinates, are you referring to the coordinate system?
BenColeman2
Hi Jake,
Thank you for the reply. I have since had a play and realised that I just needed to define the correct projected coordinate system.
Thanks for the help,
Ben
third link in my post
