How do I project a dwg file with unknown coordinate system
1781
6
04-14-2017 01:07 AM
JamesLyles1
JoeBorgione
It might be easier to spatially adjust the dwg with a known feature class or aerial photo:  About spatial adjustment—Help | ArcGIS for Desktop .
That should just about do it....
DanPatterson_Retired
First, you have to identify the unknown coordinate system and only then can you project it
JamesLyles1
thank you.
I was surprised to find that georeferencing worked with *.dwgs!
JoeBorgione
JoshuaBixby
MVP Esteemed Contributor
For future reference, the "GeoNet Help" space is for help with GeoNet itself, not general help from GeoNet users.  If you explore the https://community.esri.com/docs/DOC-1544-geonet-community-structure?sr=search&searchId=b75988ae-dd52...‌, posting to a more relevant space or place usually leads to more responses.
JamesLyles1
Sorry - Will find another source of information.
Didn't mean to walk on your grass.
LaluVijayan
Hi , you have to define the projection which  coordinate zone you are looking , then go throuh the project the coordinates BY Arc tool box-Datamangement-projection and transformation.
