Hey guys,
I have an issue similar to this...
I know how to fill a field with the coordinates of points using the calculate geometry function. However, of the scales that I can select from, I cannot select Lat and Long but I can select decimal degrees. What I'm wondering is if it's possible to create, for example, a new field and use a python statement to manipulate the field filled with the decimal degrees to convert them to lat and long coordinates.
-Andrew
