Resolved the problem re inverted ECW images. Had to use ECW Header Editor and change the setting regarding direction of Y coordinates. In the southern hemisphere the latitude coordinates increase downward, 0 to 90. But realising that southern hemisphere latitude numbers are defined as a negative number then the Y coordinate would in fact increase upwards, -90 to 0.
