Limitations of ArcView 10 with SDE???
547
11-16-2010 05:07 AM
philippschnetzer
Occasional Contributor III
I am under the understanding that an SDE geodatabase cannot be created with ArcView, only ArcEditor/Info.  But, I would like to know if there are further limitations beyond that - once the SDE is made (using Editor of Info) can ArcView 10 make the direct connection to it through ArcCatalog, load an SDE feature class in ArcMap, make edits to the layers, add new layers, etc....
Is there a good matrix chart comparing the licensing levels anywhere - haven't found one yet...?
Thanks!!
DerekLaw
Esri Esteemed Contributor
Hi Philipp,
Please review this help doc:
ArcView and the geodatabase
Hope this helps,
philippschnetzer
Thank you, Derek.  Very helpful!
