Hi Rawan,
We'll need some additional information to better understand the factors that could potentially be affecting the performance you're witnessing.
- What version of SQL Server are you using?
- What is your ArcGIS Desktop/Enterprise geodatabase version(s)?
- Is the client machine that you are making these edits on located on the same machine as the database server?
- What type of geometry are your feature classes stored in?
- Is the performance issue strictly limited to editing operations? Is panning/zooming slow? GP tool performance?
- Have you always witnessed latency or is this something that has recently occurred?
- Have any architectural changes occurred recently? DBMS Upgrade? Moving data to a new server?
- Are your feature classes registered as versioned?
- How often do you run geodatabase maintenance?
- Is performance only witnessed on this single feature class or is it database-wide?
Regards,
Quinn
