I'm trying to find the nearest address for a series of points. I have a parcel layer i'm trying to use for addresses.
I was able to use the Reverse Geocode (RG) function in ArcToolbox to get a start. However, i had to use an address locator based on a street centerline file. Upon inspection of the addresses, the addresses the RG found were linearly interpolated from the addresses in the "line" data from the street centerline file. Consequently, a lot of those addresses do not exist.
I tried to create an address locator with Parcels, and then RG the points. Everytime i did this ArcMap crashed. I'm assuming you can't use an address locator built with polygons to RG.
Any idea how i should go about doing this? I have roughly 40,000 points that need a closest address.
Steve
