sdelayer based on SDO_GEOMETRY view not shown in ArcGIS: spatial index does not exist
4711
6
10-31-2012 07:32 AM
CarelBodegraven
New Contributor III
We need to use the outlines of a multipolygon layer SDO_GEOMETRY in an Oracle database as a multiline layer in SDE. We would like to maintain a dynamic relationship with the original polygons-layer.
Therefor in Oracle we made a database view, changing the the geometrytype to line using "sdo_util.polygontoline(shape)", which resulted in correct values in the Shape-column: MDSYS.SDO_GEOMETRY(2006... and MDSYS.SDO_GEOMETRY(2002...
After that we applied "insert into user_sdo_geom_metadata values...." to the view
And we registered the view as a layer in SDE: sdelayer -o register...
In ArcCatalog the table is now correctly presented in ArcCatalog as line-layer. The lines, however, are not visible in ArcMap. Just when you select a feature in the feature table it does show exactly like a selected feature in any other (valid) layer.
When using a tool on the layer, I get the error: Spatial index does not exist [ORA-13226.......
We tried several things like sdelayer -o normal_io
Does anyone have a suggestion to get the layer working properly (other then creating a materialized view)
Carel
BenLin
New Contributor III
Hi Carel,
What was your exact "sdelayer -o register" command syntax?
Have you tried using "sdelayer -o alter -E CALC" command to recalculate the layer envelop after you registered the SDO layer with SDE?
Ben L.
CarelBodegraven
New Contributor III
Hi Carel,
Ben L.
Hi Ben,
Thanks for your reaction!
I used: sdelayer -o register -i 5151 -u wshd -p password -s isp -l KERINGEN_SVW_ZONERINGEN_LN,geometrie -e nl+ -t SDO_GEOMETRY -k SDO_GEOMETRY -C GZN_ID,USER -P HIGH -x 0,0,1000,0.001 -G 28992
I just tried sdelayer -o alter -E CALC -i 5151 -u wshd -p password -s isp -l KERINGEN_SVW_ZONERINGEN_LN,geometrie
The result was "Successfully Modified the Layer"
Describe_long gives:
Layer Description ....: <None>
Table Owner ..........: WSHD
Table Name ...........: KERINGEN_SVW_ZONERINGEN_LN
Spatial Column .......: GEOMETRIE
Layer Id .............: 3790
SRID .................: 813
Minimum Shape Id .....: 1
Offset ...............:
  falsex:          0.000000
  falsey:          0.000000
System Units .........:       1000.000000
Z Offset..............:      -1000.000000
Z Units ..............:      10000.000000
Measure Offset .......: <None>
Measure Units ........: <None>
XY Cluster Tolerance .:          0.001
Spatial Index ........:
  parameter:    SPIDX_RTREE
  exist:        Yes
  array form:   -2,0,0
Layer Envelope .......:
  minx:     49185.56300,        miny:    407891.90600
  maxx:    111731.14200,        maxy:    439662.59400
Entities .............: nl+
Layer Type ...........: In-Line Spatial Type
Creation Date ........: 10/26/12 12:09:08
I/O Mode .............: NORMAL
Autolocking ..........: Enabled
Precision.............: High
User Privileges ......: SELECT
Coordinate System ....: PROJCS["RD_New",GEOGCS["GCS_Amersfoort",DATUM["D_Amersfo
ort",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UN
IT["Degree",0.0174532925199433]],PROJECTION["Double_Stereographic"],PARAMETER["F
alse_Easting",155000.0],PARAMETER["False_Northing",463000.0],PARAMETER["Central_
Meridian",5.38763888888889],PARAMETER["Scale_Factor",0.9999079],PARAMETER["Latit
ude_Of_Origin",52.15616055555555],UNIT["Meter",1.0]]
Layer Configuration ..: SDO_GEOMETRY
However: the layer still does not draw in ArcCatalog
VinceAngelo
Esri Esteemed Contributor
Do the geometries contain Z values (elevations)?  The coordref has a Z origin and scale,
but the entity flags don't support elevations ("nl+" vs. "nl+3")
CarelBodegraven
New Contributor III
The geometry does not contain Z-values:
MDSYS.SDO_GEOMETRY(2002,28992,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,2,1),MDSYS.SDO_ORDINATE_ARRAY(51455.605,426561.375,51447.652,426558.813,51427.699,426553.625,51413.66,426551.031,51405.637,426548.5,51396.461,426548 etc.
However, neither does the original polygon layer (gw_gzn) from which the view was derived, and that layer was also registered with:
I think I forgot to mention the -z -1000,10000 in my earlier statement, sorry about that.
TravisVal
New Contributor III
To get this to work, I think you have to create a function-based index on the output of the SDO_UTIL.POLYGONTOLINE function.
What tripped me up was that you have to fully qualify the function name when you inset the row into the sdo_geom_metadata view.  If you don't, you can't create the index.
good luck
Travis
create view view_outline as select objectid, sdo_util.polygontoline(shape) shape from data_table;
View created.
select count(*) from view_outline where sdo_filter(shape,
 SDO_GEOMETRY(2003, NULL, null,  SDO_ELEM_INFO_ARRAY(1,1003,2),  SDO_ORDINATE_ARRAY (1, 1, 30, 30))) = 'TRUE';
ERROR at line 1:
ORA-13226: interface not supported without a spatial index
ORA-06512: at "MDSYS.MD", line 1723
ORA-06512: at "MDSYS.MDERR", line 8
ORA-06512: at "MDSYS.SDO_3GL", line 1248
ORA-06512: at "MDSYS.SDO_3GL", line 1393
insert into user_sdo_geom_metadata values ('data_table', 'MDSYS.SDO_UTIL.POLYGONTOLINE(SHAPE)', SDO_DIM_ARRAY(SDO_DIM_ELEMENT('Lat', -180, 180, 0.05), SDO_DIM_ELEMENT('Long', -90, 90, 0.05)), NULL);
1 row created.
create index base_table_fidx on base_table(sdo_util.polygontoline(shape)) indextype is mdsys.spatial_index;
Index created.
  COUNT(*)
         9
CarelBodegraven
New Contributor III
Thanks a lot Travis! this does the trick: a dynamic line-layer view on a sdo_geometry polygon-layer-table!
