something is wrong with the file.
Can you add it all by itself to a map and view it? (no basemap, no other data)
Can you open the table?
What are the extents of the file (left, right, top bottom)? check under the layer properties.
What Is the coordinate system supposed to be in light of the extent? Does it look like decimal degree data? or does it look like it is projected?
... sort of retired...
