What kind of database is it?
If it's Oracle, then you could use the SQL from this post for coded value domains: Select domain codes/descriptions.
--create or replace view d_all_coded_value_domains_vw as
select
cast(rownum as number(38,0)) as rownum_,
x.code,
x.description,
i.name as domain_name
from
sde.gdb_items_vw i
cross apply xmltable(
'/GPCodedValueDomain2/CodedValues/CodedValue'
passing xmltype(i.definition)
columns
code varchar2(255) path './Code',
description varchar2(255) path './Name'
) x
where
i.name is not null --https://gis.stackexchange.com/questions/434701/find-problem-domains-in-gdb-items-vw
And this post for subtypes: https://gis.stackexchange.com/a/434583/62572
--create or replace view sub_lc_events_asset_class_activity_vw as (
select
x.subtype_code,
x.subtype_description,
x.subtype_field,
x.subtype_field_domain,
i.name as table_name
from
sde.gdb_items_vw i
'/DETableInfo/Subtypes/Subtype/FieldInfos/SubtypeFieldInfo[FieldName="ACTIVITY"]'
columns
subtype_code number(38,0) path './../../SubtypeCode',
subtype_description varchar2(255) path './../../SubtypeName',
subtype_field varchar2(255) path './FieldName',
subtype_field_domain varchar2(255) path './DomainName'
) x
where
i.name is not null
and i.name = 'INFRASTR.LC_EVENTS'
Or use the sample Oracle or SQL Server queries here:
Example: Resolving domain codes to description values using SQL
