Can it be true that the Trim tool on the Advanced editing toolbar will only work with Line features? Is there a way to Trim multiple lines to a polygon edge? I can't use the Trim Line GP tool, these are not all dangles, They need to be inspected...
While actively editing, the only way I know of is to select the lines and use the split tool with intersection snapping. This is unbelievably tedious as each line has to selected, split, and the part to delete must be selected and deleted.
I suppose I could make a "construction line" feature class, make my trim lines there, and run the Trim tool using the selected "trim" lines to Trim my line features... seems ridiculous... Anyone know of a better way?
