I am looking for information on how to delete a feature class from an enterprise geodatabase that appears to have become corrupted and is giving us errors with every action we take. In the process of trying to replace a feature class with a new one, a user tried to delete a feature class that had archiving enabled and it failed to delete (archiving was not disabled first). They then changed the name of the feature class so they could complete the replacement. We have since tried to disable archiving then delete, however we get "DisableArchiving: ERROR 003644: Underlying DBMS error [ORA-00904: "GDB_TO_DATE": invalid identifier]". When we try to delete the feature class (we tried right-click delete, and the delete geoprocessing tool), we get "ERROR 000601: Cannot delete XXX. May be locked by another application. Delete item [Error]: Underlying DBMS error [ORA-00904: "GDB_TO_DATE": invalid identifier]". I get the same ORA-00904 error when attempting to view the attribute table. There is also an associated feature XXX_H. I believe this was created when they tried removing the archiving and I'm assuming selected to save the history.
Other actions were also taken in an attempt to fix the issue, but I do not know everything that was tried. I believe the SDE tables got hosed up during this process.
I am hoping to find a procedure to cleanly delete the feature class manually from SDE. Or a way to fix the "GDB_TO_DATE" error so that we can delete the feature through ArcGIS Pro. This is a production database, so we are trying to avoid causing any further issues with any other data.
We are using ArcGIS Pro 3.2. The enterprise geodatabase is version 10.9.1, Oracle version 19.19.0.0.
Appreciate any assistance. I have been searching but cannot find a thorough answer that fits our issue.
Thanks!
Kim
You need to stop all ArcGIS Server Services that connect to the Oracle Geodatabase that you are trying to make schema changes (e.g. delete a featureclass) and also ask all users to close ArcGIS Pro.
You also need to close ArcGIS Pro on your machine, then, open ArcGIS Pro again and click only on the geodatabase connection file of the data owner user that you want to delete the featureclass.
If you click on any other geodatabase connection file then you can cause a lock on the geodatabase again and you will not be able to delete the featureclass.
Manage connections to a geodatabase in Oracle—ArcGIS Pro | Documentation
If the "sde" user, which is the geodatabase repository owner, does not have the kill session privilege granted in the Oracle database then you will need to ask the Oracle Database Administrator to kill the connections for you.
I hope this helps.
Thank you for the reply, unfortunately that did not help with our issue. The feature is not currently used in any services and we tried with a brand new pro project with no other open connections. We are unable to remove the archiving due to the "DisableArchiving: ERROR 003644: Underlying DBMS error [ORA-00904: "GDB_TO_DATE": invalid identifier]" error. We get that error when right-clicking on the feature and unchecking the archiving box, as well as using the disable archiving geoprocessing tool. We're going to open a ticket with esri unless we find any other fix for this issue.
You need to work with your Oracle Database Administrator to capture an Oracle Trace when you try to delete the Featureclass. This will show more details, the Oracle Trace captures all SQL Statements been executed and any errors as well, you also need to capture the SDE intercept.
How To: Set up an SDEINTERCEPT Log File on a Client Machine for ArcGIS Desktop and ArcGIS (esri.com)
This will help Esri Technical Support to identify the problem.
ORA-00904 - Database Error Messages (oracle.com)
"The identifier or column name entered was invalid."
You can use Oracle SQL Developer to check the fields in the Featureclass base table, A table ( if registered as traditional versioning), the Archiving Table and the Multi-versioned View (_EVW View).
It is complaining about the GDB_TO_DATE field, then check the archiving fields.
Log in as the SDE user in Oracle SQL Developer, run the following query to get a list of columns recorded in the system table.
SELECT * FROM COLUMN_REGISTRY WHERE TABLE_NAME = '<feature_class_name>';
Compare the list with the fields shown in the feature class properties dialog box in ArcGIS Pro and with the list of fields shown by Oracle SQL Developer when describe the featureclass base table columns.
