Hello,
I attempted a view where a polyline is converted to a point using a buffer around the polyline, it then calculates the centroid of the buffer to set a point.
The result is a working view, the table is complete and the items are selectable. However the geometry is not visible! I am able to select and export the geometry to a shapefile, the shapefile does display the geometry.
The steps I took:
CREATE
OR REPLACE FORCE VIEW INTWIS2.
KDU_MIDPOINT_VW
KDU_ID
KDUIDENT
GEOMETRIE
AS
SELECT c.KDU_ID
c
.KDUIDENT
SDO_GEOM
.sdo_centroid
SDO_GEOM
.sdo_buffer (SDO_GEOM.sdo_mbr (geometrie), 1, 1
0.01
GEOMETRIE
FROM gw_kdu c, user_sdo_geom_metadata
m
WHERE m.table_name = 'GW_KDU' AND m.column_name = 'GEOMETRIE'
CREATE
OR REPLACE PUBLIC SYNONYM KDU_MIDPOINT_VW FOR INTWIS2.KDU_MIDPOINT_VW
GRANT
SELECT ON INTWIS2.KDU_MIDPOINT_VW TO GEOWEB3
GRANT
SELECT ON INTWIS2.KDU_MIDPOINT_VW TO INTWIS_BASIS
GRANT
SELECT ON INTWIS2.KDU_MIDPOINT_VW TO INTWIS_LEZEN
GRANT
SELECT ON INTWIS2.KDU_MIDPOINT_VW TO SDE WITH GRANT
OPTION;
I then registered the view using sdelayer:
sdelayer –o register –l KDU_MIDPOINT_VW,GEOMETRIE –e p -t SDO_GEOMETRY –C KDU_ID,USER –k SDO_GEOMETRY –P HIGH –x 0,0,5000,0.02 –G 28992
USER_SDO_GEOM_METADATA is filled:
INSERT
INTO USER_SDO_GEOM_METADATA (TABLE_NAME
COLUMN_NAME
DIMINFO
SRID
VALUES ('KDU_MIDPOINT_VW'
'GEOMETRIE'
MSDYS
.SDO_DIM_ARRAY (MDSYS.SDO_DIM_ELEMENT ('X', 70000, 180000, 0.01
MDSYS
.SDO_DIM_ELEMENT ('Y', 480000, 580000, 0.01)), 28992
Thats it.
I got a materialized view working using pretty much the same statements, however I want the view to update live if new records are added to the base table.
Any ideas?
