what is geodatabase and why is it different from shapefile?
31456
6
10-18-2011 12:00 AM
nunupodi
Hi there,
i am new to gis, and i would like to learn more about it. Now I get confuse what are the differences between geodatabase and shapefile. And if we have geodatabase, do we need to convert it into shapefile so that we can use it as a layer? Please advice.
Looking forward for nice people to explain.
VinceAngelo
Esri Esteemed Contributor
Geodatabases and shapefiles are two different storage formats for spatial data. Shapefiles
were originally created in the 1990s for use with the original ArcView. They use the dBase-III
format to store attributes, and are subject to many limitations (among them: lack of numeric
nulls, very short column names, day resolution dates, and short ASCII strings). "Geodatabase"
is not a single format, but a family of formats that take advantage of true database concepts
and support a wider range of datatypes, NULL columns, and raster datatypes. All modern
Esri GIS applications can directly read geodatabases; not many others do. There's probably
several hundred pages of documentation which touch on your topic, but if you start with
something like A quick tour of data management, you'll have a good beginning.
- V
nunupodi
thanks vangelo. So, what are the condition that we need to create geodatabase instead of using shapefile.
VinceAngelo
Shapefiles are larger, slower, and less flexible than file geodatabases. Most importantly, they
are "lossy" (what you get out isn't what you put in -- truncating column names, restricting
string fields to 254 characters, no international character support, poor resolution on dates,
"zeroification" of NULL numeric values,...). I can't think of one reason to use shapefiles when
a file geodatabase is an option.
- V
AlexeyTereshenkov
Regular Contributor III
Agreed with Vince.
You would want to use personal or file geodatabases (which depends on your business workflows) whenever possible. However, keep in mind that non-Esri applications are not aware of file geodatabase format since it is essentially an encrypted folder (unless you want to work with File GDB API - http://resources.arcgis.com/content/geodatabases/10.0/file-gdb-api).
Personal geodatabases can be accessed by non-Esri software that "understands" MS Access database format (of course we are talking about tables and not geographic datasets).
That is why you would want to use shapefiles - this is an open format which you can work with in various software (http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf). This is the reason why, for example, largest data vendors like Navteq and TomTom deliver their datasets in shapefile format.
VinceAngelo
Just one note to add on the "personal geodatabase" format -- Esri has deprecated support for
Access-based geodatabases. 64-bit ArcGIS Server 10.1 will not support this format. Desktop
will support it for a bit longer, but if you're just starting out, there isn't much good in heading
down a known cul-de-sac with a sign stating "Dead End."
- V
DerekLaw
Hi Nunu,
Just to add onto what others have posted, you may want to listen to this podcast:
An Overview of the Geodatabase and Five Reasons Why You Should Use It
It's available from here: Esri Instructional Series Podcasts
(do a filter for Geodatabase)
Hope this helps,
