XML Import Failing : 160320: The subtype code does not exist.
453
12-11-2023 10:28 AM
JacquelineAlessi
Occasional Contributor II
Hi I am trying to import a FGDB Schema from XML, the XML export of the schema worked fine. However upon import I get the following error: 160320: The subtype code does not exist (Name)
There is no subtype by the Name listed in the error in the FGDB, there is a FC by that name. How do I determine the root cause and resolve it? There are no resources available online for this error code.
MarceloMarques
You can try to import one featureclass at a time till you discover which featureclass is causing the issue, then you can dig more into the domains of that featureclass to find out what the problem might be.
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
JacquelineAlessi
Thanks Marcelo, we are in the process of doing that now, but we have 15k classes in this DB. OOF.
MarceloMarques
You could try to write a SQL query to access the geodatabase domains information of your ArcSDE Geodatabase to try to identify the featureclass(es) and domain(s) causing the issue.
Example: Resolving domain codes to description values using SQL—ArcMap | Documentation (arcgis.com)
Example: Discovering domain usage using SQL—ArcMap | Documentation (arcgis.com)
