Hi, I am building a model in ArGis Pro and I am attempting to add the erase point tool and when I try to run it the system crashes. Any idea why? And can someone explain how I can remove the additional points outside of the buffer layers, is it with the clip tool? I first set a buffer tool and the input is set to parameter and I am attempting to have the points outside of the buffer zone to be removed when you run the model, any suggestions?
