You could use a field calculation (Python parser) using the following function:
def ChangeInch2Feet(txt):
factor = 0.0833333
decimals = 2
lst_in = txt.split(' ')
lst_out = []
for a in lst_in:
try:
inch = float(a)
feet = inch * factor
feet_txt = str(round(feet, decimals))
lst_out.append(feet_txt)
except:
if a == 'in':
lst_out.append('ft')
else:
lst_out.append(a)
return ' '.join(lst_out)
When you execute the calculation:
ChangeInch2Feet(!YourFieldNameWithDataInInches!)
... using the example you provided, this will yield:
0.17 ft x 0.33 ft
There might be exceptions in your data, and this function does not account for any exceptions.
