How to dynamically change dojo element values?
7316
11-04-2016 07:24 AM
ShaningYu
For the items in the Search.html, e.g. the 2 listed below:
                <label data-dojo-attach-point="labelSearchTerm0"> </label>
                <input type="text" style="width:100%;" data-dojo-type="dijit/form/TextBox" data-dojo-attach-point="inputSearchTerm0" data-dojo-props="trim:true,disabled:true" />
I want to dynamically re-set their values in JavaScript.  How to do it?  Appreciate if you can help
TimMcGee1
Occasional Contributor III
Assuming your JavaScript code is in Search.js and you want to set the value in dijit you referenced with the attach point 'data-dojo-attach-point="inputSearchTerm0"`, you would use:
this.inputSearchTerm0.set('value', 'My Value');
There are numerous additional examples of this method in Search.js. Here's one: cmv-widgets/Search.js at master · tmcgee/cmv-widgets · GitHub
TimMcGee1
ShaningYu
Thanks.  I got the same answer as you provided as I reviewed the code.
