Dear Ted, i really thank you. In fact you right i totally forgot, so yes i need also second one because when i applied that script on my map screen showing like as below.
So is there any way to just show if "Enabled" field is 'False' and when "Status" field is 'Normal' retention for 'Enabled' label. I do not want to show that Enabled label on the map because everything is allright.
thanks in advance.
